Jshoe's avatar
Jshoe
Installing 12v 30a circuit breaker for landing gear
I know this topic has been discussed ad naseum. I keep blowing my 30 amp fuse when utilizing my landing gear, (Lippert).
1.My 12V batteries are new/good
2. My landing gear does not need lubrication, nor is it binding in any way.
3. My wiring is good.
4. I am not retracting or extending gear too far.
I recently installed a 12v 30amp circuit breaker, as this has been mentioned multiple times on numerous forums. Problem is, after installing 30a circuit breaker and testing landing gear, it still blew the 30 amp fuse. Perhaps i have installed the circuit breaker in the wrong place, but i don't think so. I would add a picture, but can't seem to figure out how to add a photo.
Black(hot) wire leads from battery terminal and in to a circuit board,(not sure of correct terminology). This is where the 30a fuse is located. On other side of circuit board two wires,(white and white with black stripe), leave circuit board and tie in to landing gear motor. I inserted 30 circuit breaker on Black(hot) wire that feed power from battery to circuit breaker.
Does this sound like proper location for circuit breaker?
Does anyone thing that i need to replace my landing gear motor, as this is the only thing i have not been able to test. Thanks.
Jerry
Having RV issues? Connect with others who have been in your shoes.24,240 PostsLatest Activity: May 01, 2025
