1L243
Aug 21, 2018Explorer II
Added backup lights to 2017 Coleman 300tq. I had already added marker lights to the bottom frame below the ramp door.
I found some nice surface mount Led's 18watt flood . I wanted surface mount because i did not want the lights hanging below the frame.
You will need a 7 Way wire harness on your truck and trailer. The center pin will be wired to the backup light on the truck.
On my trailer I only had 6 wires seen plus a metal residential type electrical box that was not waterproof. So I orderd a 7 Way 8' harness with junction box that is color coded.
I fused the yellow reverse light wire with a 5 amp fuse for a 3 amp draw. I did not run a relay.
The lights sit well on the bottom frame.
The lights are bright
Lights up the RV Port well
Cost
Lights $17 each
Harness with box $37
Wire $10
Fuse harness $5
Cost
Lights $17 each
Wire $10
Fuse harness $5
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
