towpro's avatar
towpro
installing Bogart Trimetric Question
This is going into a Slide-in Truck camper. Two 27 series AGM batteries. 45 amp on board charger, solar will be between 200-280 watt (installed at a later date). I do have a Honda Generator as well.
I am going with Bogart 2030 RV, and later the Bogart Solar controller. But now I need to know should I go with the 100A shunt of 500A shunt?
500a sounds like a lot, and I would appropriate the extra digit on load display using the 100A shunt. Which one should I use?
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
