HelotesAg's avatar
HelotesAg
Installing second AC, question about tilt of unit
Thanks to several posts on this forum, I've decided to add a second AC to my fifth wheel. My plan is to remove a vent at the front of the trailer and install the AC. The way my trailer is built, the roof slopes down in the front so if I were to install the AC as-is, the front of the AC would tip downwards.
The AC manual says that the front can tip up, but not down, but I'm curious as to why. I started paying attention today and I saw at least two 5ers on the road today with an AC on the front half tipping down.
Does anyone know why the front shouldn't tip down?
FYI I bought a Coleman 9200 Polar Cub AC.
Thanks in advance!
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Install it backwards so the "Front" becomes the "Rear" no reason to have them always face the same way save one... The design is such the rear is where the "Delecate" parts are, (The parts you do not want slapped by tree limbs) so you may need to install some kind of protection if you put it in that way.
    Automatic louvers should work, so long as you do not run it while driving.
  • Thanks for the advice everyone. I presumed it was because of the condensation. I'm going to get it out of the box tomorrow and up on to the bench, open it up to see if I can figure out how it drains.
    Thanks!
  • Ivylog's avatar
    Ivylog
    Explorer III
    OnaQuest wrote:
    Ivylog wrote:
    Because they say not to and so the water will drain out. Turn the unit around so the front is facing to the rear. Unlike with a MH you will not be running it going down the road so air flow while moving will not be a problem.
    ....and let the wind resistance rip the shroud right off.
    Guess you've never seen a rubber roof bubbled up at the front from the low pressure area created by the air off the front of the rig.
    If Doug Rainer says it's OK sloped down... go for it.
    ,,,,and I spect big ol bugs might fuzz up the condenser fins.
    Oh and BTW,did anyone caution you about possiable condensate leaking?:R
  • Mine is a dometic and it faces front down with no problem. That being said, the end down is actually the rear of the a/c. As mentioned by Fred, take the cover off and I think you will find a port for drainage at each corner.
    Good luck!
  • I have NEVER in 34 years as a tech had any problem with a AC unit on a downward or rearward slope on a RV. You can install that unit with no problem. The REASON for that disclaimer is to cover the AC maker from the IDIOTS out there that would install it on something that had a severe slope other than an RV. The downward slope on a 5th wheel at the front is NOT that severe. Doug
  • Ivylog's avatar
    Ivylog
    Explorer III
  • Hi,
    THe indoor coil has a drain line, and the evaporator gets down to about 40F, cooling the air, and also collecing moisture, much the same way a cold drink will be covered with moisture on a warm humid day. Even if the air is fairly dry, it can still produce a quart of water in a couple of hours.
    I guess that this manufacture says it can tilt with the front up, but not front down. If you are really curious, then take off the outside cover, and inside cover, you might find the evaporator eventually, and find out that the evaporator drain tube is on the rearward right or left (or both sides) of the evaporator, with a small 3/8" tube going to the outside of the unit.
    Fred.
  • Call the manufacture's support phone# in your owner's manual,meanwhile we will assume it has to do with condensate running places you don't want it to.:W
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
