wa8yxm
Jun 15, 2014Explorer III
Paul Clancy wrote:
was quite amazed. I'm not saying this will work for any ac in any condition but if you already own a 2400 yam don't assume it won't run your 15000 ac.
I am not so amazed... Here is an interesting factoid.
My 50 amp RV came with two A/Cs. both carrier Air V, both 13,500 BTU, both draw 13.5 amps running, I have verified by testing with clamp on ammeter.
Well due to faulty workmanship one failed, out of warranty and Carrier no longer does RV A/C.. So I replace it with an advent air 15,000 BUT, Which, today I am truly enjoying (I could use even more BTUs.
The Advent air also draws.. running.. the very same 13.5 amps
Yes, more cold, same power.. newer A/Cs are more efficient as they improve the design.. So your 2014 may well draw even less power than my 2012 (but not likely) advent air..
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
