Last_Train
Sep 18, 2018Explorer
Lynnmor wrote:Last Train wrote:
The other question is why is there a drop in voltage from one side of the trailer to the other?
I would check multiple times in case the converter is switching modes or other items are switching on and off.
When the voltage can be repeated, then suspect a poor connection. Also try swapping the fixtures to see if the problem follows the fixture.
Thanks. Good points. As it turns out I had checked the voltages over a two day period, and the variances were consistent. Before swapping with the known good fixture I wanted to hear the wisdom from this forum. I will remove the factory connections and assure that I reattach with a solid crimp.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
