Linedog's avatar
Linedog
Interior LED lights.
OK I'll be the first to admit that I'm no rocket surgeon but my pin head got to thinking. I was in CW and was looking at the wedge base LED lights, and wow they look a lot like my Malibu outdoor 12 volt lights. So I bought one, at $13.50 I'm only buying one that's for sure. At home I open my Malibu lighting and replace the bulb with the LED unit and it fires right up. So into the trailer we go, I remove a stock C-921 bulb and insert the LED, and it fires right up. I replace the LED with a Malibu light and it fires right up. Does anyone see a pattern here? What's to stop me from ordering 10 LED bulbs off EBay at roughly $2.25 apiece and trying them? Anyone else try this and have good results?
  • If running off of 12VAC one can expect a significantly less lumen output. The device PIV value will handle it.
  • If the landscape lamps are the round flat type with 12 or 24 surface mount less, they should work quite well. The 12 led are type 5050 and the 24 led type are (if I remember correctly) type 1210. If they are in warm white, and if you are happy with the light output, try them. They are cheap enough.
    I have used the 36 type 1210 and the 15 type 5050 led panels, and I prefer the 15 type 5050 ones. On the 36 led panels I notice some shadowing when I read, and the denser layout seems to result in soldering problems that cause one or two groups of three to not light.
    I've not noticed any rfi problems, but wouldn't expect to with fm or digital TV. I mostly camp off grid and value the reduced current draw. Plugged in at home they work fine.
  • I ordered the 10 piece lot of the 24 led array yesterday and received this email form them today.
    Hi Sir, thanks for your order, the unit price $0.84/piece product is 6 5050SMD LED, Not the 24LED shown in the photo, the dimension is 3.5x2cm.
    Please confirm if it is ok, or we can refund your money to you when you cancel your order. Thank you!
    China - Go figure.
    China - Go figure.
    The 6-5050 light will probably not be as bright as the 24-1210. I'd say find another vender.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
