joe0508's avatar
joe0508
interior light
I have a 92 thor pinnacle.There is a toggle switch up front in the cockpit that turns one of the ceiling lights on in the middle of the coach.It has stopped working.I tryed another bulb from another light that i knew worked but it didnt when i tryed it.Could there be a blown fuse and if so where would i begin to look?Also there is a small light that used to come on when you power on the switch but now it dont.
  • Gjac's avatar
    Gjac
    Explorer III
    Check to see if there is 12v at the light it self with your multimeter, if not go to your 12 volt house fuse panel not the chassis panel in the engine compartment and look for some thing that says 12v lights and check that fuse. If it is not marked check them all you will probably find a blown fuse there.
  • othertonka wrote:
    if the ceiling light also has a switch, try it in both positions why you try the up front toggle in both positions. Could be the light was ON and someone turned it off at the light fixture. If that does not work look for a 12 v blade type fuse. It could be in or near the main breaker panel.
    I forgot to add that i have already tryed that method and it didnt work.It seems that it is not getting power at the switch.When you say main breaker panel are you talking about the breaker panel in the rear over the bed or the fuses in the dash?
  • if the ceiling light also has a switch, try it in both positions why you try the up front toggle in both positions. Could be the light was ON and someone turned it off at the light fixture. If that does not work look for a 12 v blade type fuse. It could be in or near the main breaker panel.
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Mar 27, 2018
