I rewired my trailer with a square box, two fuses have incoming power. On from shore power and one from the inverter. I can not figure it out but each hot fuse only powers certain load fuses (no I d...
It seems you're trying to use a 220 volt service panel with two independent 120 volt sources. Each source can only power the breakers on it's own bus. If the inverter is on full time, then place only the breakers you want powered by the inverter on that bus, with the others on the shorepower bus.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
