I rewired my trailer with a square box, two fuses have incoming power. On from shore power and one from the inverter. I can not figure it out but each hot fuse only powers certain load fuses (no I d...
As others have pointed out, You are out of your league doing this type work. For instance, you state lights. Lights are 12 volt. Also, the 240 breaker panel usually has every other breaker on a leg. Leg one will be breakers 1/3/5/7. Leg 2 will be 2/4/6/8. Last, you CANNOT expect to run a roof AC on an Inverter. A 2500/3000 Inverter will run a roof AC, but kill the batteries in less than 4 hours. Probably less than 2 hours. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
