jeeperdude10's avatar
jeeperdude10
Intermittent fan\ac
Last night I wanted to use fan only just for circulation and it would cycle, just like when ac is on. Is this normal? Thermostat issue or possibly campground electric hook up issue, we do get 115-120 volts at outdoor receptacle.
  • jeeperdude10 wrote:
    Dometic electric t-stat and dometic 13,500 BTU ac unit. It is cooling okay but fan just stops intermittently when running on its on w/o AC cooling.
    Works OK when in .auto. and running with A/C but when in ON fan runs intermittently??
    Sounds like t-stat switch/contacts.
    Is it an analog type t-stat........if it is replace with a digital
  • Dometic electric t-stat and dometic 13,500 BTU ac unit. It is cooling okay but fan just stops intermittently when running on its on w/o AC cooling.
  • Has nothing to do with CG voltage
    Thermostat....
    Select fan ON and it should run until you turn it off
    Could be issue with t-stat or run capacitor for fan
    What A/C unit and which t-stat??
  • You didn't specify what exact hardware you are using, but some models of fans have a thermostat built in.
    The "fantastic fan" models that I have will cut on and off dependent on the temperature.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
