rjsurfer's avatar
rjsurfer
Internal fuse for the WFCO 55 Amp Converter?
I just noticed that I'm not charging the batteries when hooked up to the power pole. The batteries are down to 12.0v, they should be showing at least 13.4v.
The 12 volt DC output is fine, all the lights work as does the fridge and propane detector etc.
My question, is there a fuse in the converter box, I can't see because it's a closed box not like my old open frame converter?
I'm assuming I could buy a battery charger to charge the batteries until I figure out the problem. The biggest issue would be letting the batteries get too low and prevent the slides and landing gear from working?
Any help wuld be appreciated.
Ron W.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 07, 2026
