twor's avatar
twor
inverter advice
Replacing a Xantrex 400W with similar size inverter. Recommended brand to get?
I have 4 Trojans for house batteries.
  • Sounds like we have the same inverter set up , my 400 watt unit had been replaced by a previous owner with a xantrex SW 600. It's been working great for the 5+ years I've used the coach. Looks like the replacement would have taken a half hour at most. It's all the inverted power I need, right now. No charge function required.
    If I install a residential fridge , I would up grade.
  • I recommend the GoPower 300 watt sine wave inverter. Very low idle draw and a provision to add a remote switch.
  • OP didn’t mention microwave. He’s been ok with 400 watts.
  • 3_tons's avatar
    3_tons
    Explorer III
    wa8yxm wrote:
    I will second Ron you might even consider an inverter upgrade to power more you have enough battery to feed up to about a 2000 watt and nuke lunch.
    X2, a ProWatt 2000w sine-wave is a good match for most microwaves...
  • Doesn’t inverter efficiency peak when the unit is operating close to its max? If that’s true, buying a larger inverter than necessary wastes power. See this article and chart:
    https://www.solarquotes.com.au/blog/two-reasons-you-must-look-at-efficiency-curves-when-choosing-your-solar-inverter/
  • wa8yxm's avatar
    wa8yxm
    Explorer III
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Xantrex is known for making good inverters. Samlex pro series and Morningstar are good brands too. You want something quiet. The cheap inverters have loud non thermo controlled fans that run constantly.
