- GBaxterExplorerChris is right leaving the inverter ON (Xantrex, Magnum etc.) is really just ENABLED. While plugged into shore or running the generator the ac power is "passing through" the inverter which means it simply comes in on the input and passes directly to the output. It is not filtered or manipulated in any way so leaving it ENABLED only leaves it ready to start inverting if ac input power is lost.
So to answer the original question you can leave the inverter ON/ENABLED all the time it won't make difference as far as longevity to the components.
Gary - Chris_BryantExplorer II
Almot wrote:
There is NO benefit in running a device that you don't need. None, zero.
I disagree- I'm not sure about the Magnum, but Xantrex models switch over as fast as a UPS, so by leaving the inverter enabled, what ever is power through it will have an uninterrupted power supply.
Note that leaving it "on" is really just leaving it enabled, as it is not doing anything when supplied with shore power. - MNtundraRetNavigatorWell since it is winter here at home in Minnesota (Temperature of -10F), and I am retired, and getting "cabin fever", I have a nerdy question to ask.
Converters convert 120v, ac, to 12v, dc.
Inverters convert 12v, dc, to 120v, ac. They also draw some over-head current from the battery(s) if left turned "ON" or in standby.
So; "Why would anyone using an RV ever want to leave the Inverter turned on? :h I am not counting specialized equipment used in industry.
I realize that many posters are confused because of Manufactures habit of muddying the waters quirky naming of their products.
Such as:
Generators sometimes called inverter/generators
Converter/chargers being called inverter/chargers (you still need a converter)
Are some Class B's really a Class B or a C?
Old antennas for any signal now sometimes called "HD"
I guess without all the confusion there would not be much hash over in the winter months. :B - AlmotExplorer III
SPRING STREET wrote:
Y...was wondering if i needed to leave the inverter on when i am on shore power, or if it would be of any benefit it it was left on.
Dave: what Gbaxter said. On when you need it, off when you don't. There is NO benefit in running a device that you don't need. None, zero. - SPRING_STREETExplorer
Almot wrote:
BFL13 wrote:
IMO the OP meant "converter"
Yeah... God knows what they meant indeed... There's quite a difference between converter and inverter, isn't it...
Inverter !! - SPRING_STREETExplorerYes GBaxter you are correct. I was talking about the inverter. I have the Magnum Energy System on my RV which has the Charge and the inverter on the same panel. I always leave the charger on but was wondering if i needed to leave the inverter on when i am on shore power, or if it would be of any benefit it it was left on.. Usually the only time I turn it off is if I am dry camping and leave the coach for a long time to save on battery drain. . I do have it set so the genny will turn on automatically if the amps drop below a certain point !! Being that the RV is winterized and hooked to shore power my question was leave the inverter on or off ?? or does it make a difference. Thanks for the responses! Dave
- GBaxterExplorerThe OP shows a 2005 Mountain Air which did come with an inverter/charger so I believe the question is about the inverter portion.
As mentioned already in previous posts you can leave the inverter on all the time if you want but realize if shore power goes off it will switch to using batteries. I would leave it ON all the time if I had a residential refer otherwise use it like a light switch, on when you need it off when you don't to save battery power.
If the question is about the charger you can leave that on all the time also it should not overcharge the batteries even in storage.
Gary - AlmotExplorer III
Yeah... God knows what they meant indeed... There's quite a difference between converter and inverter, isn't it... - mlts22Explorer IIThere are some inverters which are made to actively be in the main power circuit at all times, and function similar to an online UPS. Victron and Magnum Energy make them. The nice thing about these is that if there is a power blackout or brownout, the inverter will make up power from the batteries, so nothing that it is feeding would notice the glitches.
- wolfe10ExplorerActually, it depends on WHAT inverter (or is it an inverter/charger) you have AND how it has been programmed.
Please tell us what you have.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
