Lakejumper's avatar
Lakejumper
Inverter Doesn't Turn On
I'm dry camping and tried to turn on the inverter and am not getting power. I have the Xantrex XM1000. It worked fine 5 weeks ago when dry camping. I was able to use all of the AC plugs when I was hooked to shore power several days ago. All of the AC plug receptacles work when the generator is on. The GFCI plug on the inverter and the 15 amp button appear to be okay. I plugged/unplugged the cable from behind the remote panel and still no power at the remote panel. My question is if the inverter is bad, why would the plugs work with the gennie on in the RV. Or, could I have a bad remote panel? It plugs into some type of inline coupler.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
