MP_soldier's avatar
MP_soldier
Inverter won't turn off.
So my 13 month old Nature Power PSW http://www.naturepowerproducts.com/product-details.php?id=130 is on the fritz.
When I push the button to turn it on, it turns on.
When I push the button to turn it off, it STAYS on!
I have to actually disconnect the battery to get the inverter to turn off.
Anybody every have that problem?
I'm out of warranty, so I'm wondering if buying the $40 remote switch will bypass the mounted switch and get everything back in working order. It's a real PITA to keep disconnecting the battery.
.....And my water pump quit working at I was packing up to head home. At least that part happend at the end of the trip!
  • 2oldman wrote:
    MP soldier wrote:
    Won't leaving it on draw power (even if I'm not using and AC devices?
    Yes. If you have a small battery array and no solar, then many people choose to turn it off.
    I have solar which is constantly charging, so to me, it's not an issue. Leaving it on does not make it wear out faster. Were I in your shoes, I might consider more battery to make up for it, rather than a switching system.
    I'm not familiar with that brand of inverter. Are they expensive?
    It was $500 from camping world..
    ….and a crazy amount to install at my local rv dealer.
  • 2oldman wrote:
    Many of us never turn the inverter off anyway. Usually it's no problem.
  • Hi,
    Add a disconnect switch in the positive wire to the inverter. Napa sells one with a plastic "key" for $7.00.
  • Many of us never turn the inverter off anyway. Usually it's no problem.
