SoundGuy
Jun 27, 2019Explorer
dave17352 wrote:
I will locate my 2 agm deep cycles, 30 amp mppt solar controller and 2000 watt inverter all in the old generator location that I removed several years ago. Presently there is just one agm in there now.
The generator comppartmment is well vented as the orignal door is on the compartment. There is plenty of room for this equipment and air movement.
Great plan!
When I replaced my worn out flooded G27 which was mounted on the trailer tongue I installed a G31 AGM in the front pass through cargo compartment. I located the inverter right beside it so the heavy gauge +/- cables between the two were just 18" long, which resulted in minimal voltage drop when the inverter was under heavy load. Worked just fine.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
