SpencerRB
Aug 08, 2013Explorer
Appreciate the opinions, on both sides.
To clarify, the inverter I plan is use is the new MSH3012M. 3k watts, 12v.
Additionally, the proposed location would be above the battery/generator box (unable to see in picture). I have not measured the compartment temperature while the gen is running but it would be a good exercise. The gen box is fully sealed from the rest of the compartment, and I could easily add some insulation if the heat transfer is too much (if it doesn't overheat the inside of the gen box).
Regarding ventilation, there are a couple 3" drain holes on the floor of the compartment. I could easily punch an exhaust hole in the side with a cpu fan if needed.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
