tkm5236's avatar
tkm5236
Inverter turns on by itself.
We are dry camping and not using any 110 appliances so we turned the remote inverter switch on our Xantrex "off". (We have solar panels and 4 group 6 batteries) but at lesst once a day the inverter turns itself on and activated the Directv box. what's causing it to turn on by itself??
  • All the DirecTv boxes I have always pull a constant load; on or off. Mebbe its right on the threshold of the xantrex trip point
  • Some cable and satellite boxes turn themselves on and "phone home" every day using a land line connection.
    If your inverter has "load sensing", this daily routine may be what is happening.
  • msiminoff wrote:
    What model Xantrex inverter do you have?
    Is "Load Sense" turned on?
    -Mark
    This is a possibility, so if the Direct TV dish were unplugged the problem would be solved with "load sense" left on if you wished.
  • What model Xantrex inverter do you have?
    -Mark
  • I would suggest turning the inverter "off" at the inverter. It is possible someone else has a remote on same RF that may turn on your inverter.
  • Boy, I don't have a clue! The thing is inverting even tho the Inverter portion is turned OFF?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
