leica69's avatar
leica69
Inverter whine - exceedingly high pitched
There is a fairly faint very high-pitched whine from our Go Power 1750W Inverter HD when it's on. We have used it since 2006 so I know that everything is correctly wired and all connections are tight. Any ideas?
  • Thanks for the replies. I forgot to mention that I am of an age where I myself don't hear the whine at all. My somewhat younger girlfriend told me about it.
  • That is the normal whine of a switching power supply. Some are louder than others but it is not an indication of anything failing. ALL inverters whine, it just depends on how loud they are.
  • Thanks for the reply. According to one of the YouTube videos the whine is a normal inverter phenomenon.
  • Do you get that noise with no fan too or just with the fan on? Fans are an easy do it yourself fix.
    Go-Power has somebody make their inverters, which may have changed since 2006. (Xantrex used to have a 1750w MSW inverter that was re-branded by several others, eg.) You can ask Go-Power (Carmanah here in Victoria) tech support about it.
    Inverters have come down a lot in price since 2006 especially if on sale, so it is not a killer to get a new approx 2000w MSW for under $200
  • I work in computers and that high pitched whine is usually an indication of a failing power supply (same sort of electronics as your inverter). The thing is, I've seen some go like that for years, and some die right away. If you're sure it's coming from the inverter I would probably just be prepared to replace it sometime in the near future.
  • I found a few google hits and a youtube video about it. Not necessarily your particular brand of inverter.
