Got it all wired up and it seems to be working good. Still need to run a few tests to make sure I'm getting good voltage and do some high watt testing.
Fans are a little loud near the unit but not bad when it is all enclosed. Idle amp draw + a small usb charger powering my battery monitor display was 1.8 amps. Switched over fine to shore power and the fans turn off at that point.
My little fridge only draws 165 watts so that was nice to see.
I did manage to cram the wiring into the inverter box but it sure was a tight fit. Actually kind of surprised the nuts held on.
