tarnold's avatar
tarnold
iPhone OBD app
What app are you using instead of the scanguagell for an iPhone. Looked at torque pro and some others but seem to be mainly for the android. I want to see rpm, water temp, and trans temp. This will be used in a 97E350. Can't seem to find any menus for the apps available?
  • I have the Dash Command and I like it with my i phone & i pad. It does not display all of the info I would like it to, but for no more than I have spent for it, I have no complaints.
  • +1 on the Edge CTS. I use to use Torque app on my Android but you can see/do so much more with the CTS.
  • I have an Edge CTS monitor on the dash. It will monitor plus read and clear codes. Easy to read going down the road also. No programmer just the monitor.
  • X2 on DashCommand. The customization potential is awesome. For daily use I use the iphone for display, and on longer trips I set up the ipad for better readability.
    I still use a ScanGauge in my other truck, and plan on getting the new xGauge for trans temp.
  • I am using DashCommand. I have it monitoring the Catalyst temps and the Boost calculation. It can read and reset codes. You need a wifi ODBII sending unit, I got mine from Amazon. ELM327
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
