BFL13
May 13, 2018Explorer II
Mex, my AGM specs say nothing about a minimum charge rate, although I gather some AGM specs have that.
You have mentioned the 20% minimum before as though all AGMs have that requirement.
Mine have a max charging rate spec of about 30%. Some AGMs have no maximum like that and say you can use a very high rate. (Might be the same ones that have the minimum rate?)
So what's the story on all that? Thanks.
