kaydeejay
Jun 05, 2015Explorer
You really need to be sure it is the element and not a fuse or the controller.
Do you have a volt-meter?
If so, with the fridge in AC mode, check to see if you are getting power to the two wires that run to the heating element. If so, a new element is in order.
If not, you need to trace back to see where the power break is occurring.
Good luck
Good luck
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jan 17, 2025
