Golden_HVAC
Jun 06, 2015Explorer
Hi,
The heating element is sitting inside a piece of steel tubing, that is inside the steel lines filled with ammonia gas. You can not apply heat in order to try to get it unstuck (like when removing a motor from a fan hub). If the element is stuck in place, it is better to leave it there, and get someone to fill your tank, than to risk damaging the $1,200 refrigerator trying to remove the stuck element.
Yes many times when the element goes bad, it will expand, and perhaps weld itself (short to ground) to the steel tubing, and be stuck there forever!
What are your other options? Get propane delivered to your site. See if the park knows anyone who will deliver to your RV.
Get a 'extend a stay' fitting on your RV, and then you can use portable 5 gallon propane tanks. I installed one on a class C, and also have one on my RV.
Look up 'extend - a - stay' at CampingWorld.com They host this website, and stock many RV related items. Look for a kit that hooks up to a portable propane tank. Then a high pressure line goes from your portable 5 gallon tank to a new fitting that is installed on your propane tank, then the factory propane regulator is installed at the outlet of the new fitting.
It is fairly easy to refill the 5 gallon tank from time to time. You would normally leave the RV tank off, but turn it on should you run out of propane in the 5 gallon tank, or decide to disconnect it and move the RV.
I left my RV parked 4 years in a row on a ranch, using the propane for the furnace and water heater. (my refrigerator worked on electric, but the gas ignighter did not work). I was able to refill the portable tank from time to time, and not need to fill the main 12 gallon tank for that entire time.
Good luck!
Fred.
Good luck!
Fred.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jan 17, 2025
