- fj12ryderExplorer IIIDiesel doesn't have the explosive properties that gasoline does though.
- LarryJMExplorer II
Naio wrote:
It doesn't seem safe but what else would I do? I haven't used my genny enough yet to know when I will need gas.
I would not recommend that, but I've done worse probably with up to 20 gal of diesel albeit for short periods. Probably a better solution would be either on the tongue or even inside the trailer on the floor somewhere like just inside the door and then just set it outside when you stop.
Larry - George_HExplorerHave you seen one of hose plastic gas cans expand, and even blow, when in the direct sun?
- 352Explorer
In the day, it was called a Georgia credit card around here
Old Days wrote:
If you have a gasoline powered truck just carry a siphon hose with the hand pump. No need for a gas can. - Old_DaysExplorer IIIf you have a gasoline powered truck just carry a siphon hose with the hand pump. No need for a gas can.
- Sam_SpadeExplorer
Lantley wrote:
Put the can anywhere but the rear bumper. Are you OK with a big explosion behind your trailer?
Well maybe except the FRONT bumper.
Are you OK with a big explosion right in your face ?? :E - Carry the fuel can empty. Use it to run for gas as needed.
- BumpyroadExplorer
PatrickA51 wrote:
. I would stop and fill a gas can if I carried one before I got to my camp site.
sounds like a plan to me, unless you are visiting several locations.
bumpy - PatrickA51Explorer
There is a Gas can set up that holds ten gallons, it mounts behind the spare tire hanger on the Jeep Wrangler, So it's not illegal. I would not carry one myself. I would stop and fill a gas can if I carried one before I got to my camp site. - LantleyNomadPut the can anywhere but the rear bumper. Are you OK with a big explosion behind your trailer?
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
