Chandalen
Jun 15, 2015Explorer
Unless you have an MPPT controller, your excess voltage (over 19v) is useless. You could run thinner wires as the voltage loss is not a factor. Make sure your controller can handle the voltage supplied. Some PWM can not.
You can easily use a switch to turn panels on and off if you desire.
I'm not seeing over 22 amps if they are all connected and at full power.. 5.7x2 and 5.24x2. Did I miss some math?
Renogy has 19.5v 100w 5.27 amp panels for $135 ea if that helps.
