wa8yxm
Oct 31, 2022Explorer III
You said you flipped the "Switch to bypass the water heater"
Never seen an RV with such a switch.. Valves yes. Switches no
If you have a SINGLE bypass valve then there is a check valve on the water heater outelt.
If you have two or 3 you need to change. there may or may not be (It is not needed. I had a 3 valve. no check vlave.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
