wa8yxm
Nov 01, 2022Explorer III
IN theory if you look at the plumbing side of the water heater you will see any check valve if installed.. alas I've never seen one so I can not testify to that.
Check valves are a pain by the way.. they clog. Stick, And so on
The two vlave system is NOT supposed to need one.. you may have a defective valve. Only the single valve system is SUPPOSED to need one.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
