Almot
Aug 04, 2014Explorer III
Is there a Neg battery cable in trailers?
Moving batteries to inside, to pass-through front storage, so I need Pos and Neg battery connections inside.
I see the red Pos cable going under the frame in front of the trailer and disappearing there (probably terminated at the breakaway switch). So I can trace it and find the best place to route it inside.
The Neg cable is a 10" pigtail of AWG 8 bolted to the tongue. Sorry no pictures, I believe most trailers have same setup. So there is no "real" Neg cable? All the big DC loads like fridge are connected to the frame with a short piece of AWG 8, and small loads like lights - with AWG 12? So I can just attach the Neg cable from battery inside to the closest point on the frame?
I'm curios - if there is a current running through the frame, then if I'm wet, I could get a shock from step voltage by placing both hands on the frame?
