lawrosa
Oct 27, 2016Explorer
55 ah would be the 50% mark.. Also 12.1 volts that you drained it down too is the 50% mark.
This AH rating is based on a 20 AH rating..
55 AH / 20 = 2.75 amps.
That means that if you put a 2.75 amp load on your battery, then in 20 hrs your will reach 50%. That is if your batterys start at 100%.
5.5 amps will last 10 hours... ect..
But you need to check voltages as most batterys are rarely charges to 100% with the crappy convertors in the RV's.
Or check with hydrometer for best accuracy..
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 20, 2026
