BFL13
Oct 28, 2016Explorer II
Let's hope you found the problem.
I have the 2025 and don't do much with the settings, so no clue about all your settings :) Mine only shows battery, not solar.
When the solar can't provide enough, there is a draw on the batts. Shows on the Tri as minus amps and no charging light. Charging light only comes on with positive amps to the battery. This also affects the reset on the AH counter if in auto.
I did have to change from automatic reset of the AH counter because of the solar. Explains that in the 2025 manual
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
