pianotuna
Oct 28, 2016Nomad III
Hi BFL13,
Actually Peukert is always "there" so going from 4 to 6 jars makes the real amp-hours used from the battery lower.
BFL13 wrote:
If your daily AH usage has not changed then it doesn't make any diff if you now have 6 instead of 4 batts for how much solar you need.
Having 6 does:
A. let you go longer without solar input, and
B. let you run the high amp draws with less voltage drop, which means staying above the inverter low voltage alarm setting better
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
