Muddydogs
Jul 30, 2015Explorer
Is there any hope for these battery's?
I have acquired 6 battery's off RV's that have set for upwards of 4 years connected to the trailers and being bleed dry by the trailers parasitic draws. I was thinking about seeing if I could bring these battery's back to life for trailer use and if nothing else a learning experience in battery charging. I will list the battery's below and what my initial readings where, The battery's are grouped in pairs as they came off the trailers.
Group 1. 2 National 6 volt battery's. Water level low but above plates. One battery showed 1.6 volts the other 2.2 volts.
Group 2. 2 12 volt Interstate group 24 battery's. Water level low but above plates. One battery showed 2 volts the other 2.5 volts.
Group 3. 2 Interstate 6 volt battery's. Water level is below the plates a ways. One battery showed 1 volt the other .5 volts. I sure this group is toast.
I have a Die Hard 60/20/2 amp charger at my disposal. I hooked the charger up to one 6 volt National battery with it set on 60 amps and read a charge reading of 8.5 on the volt meter. The 20 amp setting gave me 6.5 volts. I wasn't sure what the manual or auto mode on the charger got me so I unplugged the charger and went looking for the manual. Once I found the manual there is nothing in it about charge voltage but it does explaining the modes and how to set charge times in the manual mode. It appears that I have a charger capable of delivering a high charge to the battery's for a set time or until the charger decides its charged in auto mode.
So should I even mess with any of these battery's? If so what are your recommendation's to bring them back to life? From what I understand I will need a hydrometer to do this right as well.
