Bigguy1951's avatar
Bigguy1951
Is this slide out motor gone?
My slide out motor quit working. I checked the voltages and all seemed fine. I did find one questionable connection that I repaired. I pulled the motor, grounded the motor to the battery and then touched one of the leads to the positive post, nothing. Did the same with the other lead and again nothing. Checked the ground and it was good. Repeated the lead tests with the same results. On a whim I touched one lead (red) to positive and the other (black) to the negative and the motor turns. I assume this indicative of an internal fault. So the question, is the motor shot?
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Mar 09, 2026
