Old-Biscuit
Aug 12, 2013Explorer III
We have always had (and still do) have good col water volume and pressure.
BUT - the hot side of both the kitchen and bathroom sinks had very little flow and pressure and was only warm for a few seconds then cool again.
Good cold water volume & pressure......hot side very little flow warm/cool
Sounds like 2 problems
warm/cool is indicative of cold water mixing with hot and is typically mis-valving (bypass valve open/cracked open)
The very little flow & pressure sounds like water heater outlet check valve is sticking/failing.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
