MEXICOWANDERER
Aug 02, 2017Explorer
Need data. Hard numbers for various internal unit temperatures. On a super hot day the cooling outflow should be measured. On my big genset 210F and 160F are it. End of the line. Both are protected by Murphy Switch-gauges. Oil pressure and temp, same way. Oil temp is set to 270F. I have a tiny 125 va Sola ferroresonant line tamer connected to L1, at 55 Hz the field collapses, output ceases which powers the contactor coil. A 300 amp contactor just after the Scott connection transformers.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
