tinstartrvlr's avatar
tinstartrvlr
Jacking up a TT
Greetings all...
About to have some wheel bearing maintenance done on TT. It weighs about 7900 lbs. The tech that is going to do the work asked me about the weight, because he wasn't sure his floor jack would lift the TT. He then explained he tried to lift a 5th wheel and it wasn't stout enough.
It got me thinking that perhaps a floor jack on the frame isn't the most sensible thing to do; putting half the weight of the TT on one tiny spot along the frame. A Lippert frame no less.
Seems jacking up each axle just enough to remove the wheel makes more sense.
Any thoughts, good or bad?
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 12, 2026
