campinrooter's avatar
campinrooter
Jayco Pinnacle 5er Residential Refridgerator
Can anyone tell me how to winterize a Frigidaire residential fridge in a Pinnacle 5er Thanks
  • Need to know year model. The FIRST Jayco's with Residential refers made it difficult to get to the water line shut off valves. But, if you are blowing it out(BEST WAY), just manually cycle the Icemaker/water thru door solenoids while the air is connected. The Jayco Manual will not state how and odds are the Residential manual will not either to know how to manually cycle the solenoids. MOST Icemakers have 2 holes(using a wire jumper)in the motor valve assbly to force the icemaker to open the water solenoid. Others you have to manually turn the motor slightly to start an ejection cycle. The FIRST Jayco's did NOT have an outside access door. Does yours? Doug
    If you don't have the consumer booklet. Go the their website and look for the manual. Next, call their customer support line.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
