Bob_Vaughn's avatar
Bob_Vaughn
Jensen AMW 970
I think my entertainment center died.....the on an off switch will not turn it on but the remote will power it on but non of the functions will work....the tuner knob does nothing. The speaker buttons will not turn off the speakers, The clock can not be set........At this point what are my options...
  • I am unable to reveal any information regarding your Jensen; however, I am able to conduct a search in this page.
    mario games
  • Bob, did you ever get your Jensen AWM970 to work? Mine has the exact same problem you described in your post.
  • I found that my issue is a ground problem....I just have to figure out where it is......
  • As DFord's link indicated, look for the reset button. It may not be a button as such, but a small hole in the face that you have to insert a small thing, like a paper clip to push the button.
    Ken
  • I don't know anything about your Jensen but I can use DuckDuckGo.com to do a search. I found this link to a troubeshooting guide for your model: https://www.jensenrvdirect.com/downloads/dl/file/id/230/awm970_troubleshooting_guide.pdf
    Jensen RV Direct.com wrote:
    AWM970 Troubleshooting Guide Radio will not turn ON • Try the reset button. • Check fuse. • Check 12V+ on battery wire to radio (YELLOW wire). • Check 12V+ on accessory wire to radio (RED wire). • Check Ground. Radio turns ON, but no sound • Verify Volume¸ Fader/Balance¸ Mute controls are set correctly (see owners manual).
  • remove power for a bit and hook it back up and see if it resets
