RoadXYZ's avatar
RoadXYZ
Explorer II
Jul 20, 2013
Jensen DVD/Entertainment - 2 DVD stuck inside - Help!
Wish I could say that it was a little kid who slid another DVD inside the Jensen while there was already one inside ... but anyway
Any one have any suggestions (short of replacing unit) to how to get those DVDs out ?
Yep, forgot #1 rule - check to see if there is already a CD or DVD inside before trying to put another one in ...
This is inside the Tamarack travel trailer ..
  • K charles, that's a great idea. Better than mine. My suggestion (which I devised to solve an identical issue) was to straighten out the length of a thin paper clip then bend a small hook at the end as to allow you to get into the hole in the disk. You know the rest.
  • Its a Jensen what did you expect. If your replacing it like I and many others did already anythings better than A Jensen. If your replacing it once its out use a small crowbar and pry off the front plastic cover then pry open the disc bay, but becareful then use some needle nose pliers and pull out the Cd's from the very edge so you dont damage or scratch it.
    Good Luck:)
