ScottnSherrie's avatar
Aug 03, 2012
John Deere chassis rear disc brakes
1988 RV on John Deere chassis. Rear brakes are dragging. Cooked the fluid after 21 miles trip to the lake. Got it home by stopping every few miles to let them cool off. Checked temps with infrared temperature gauge when I got home, discs were at 440 and caliper body was at 250.
Figure I need to pull the brakes and do a rebuild, which doesn't look complicated, just time consuming and tedious. Parts manual says rear wheel brake is a Dana 080 AF 101.
Anyone have any suggestions on the best source for a rebuild kit (the seal and dust boot)?
Update: Called the local Freightliner place and nice guy said the Dana 080 AF 101 was the rear axle (which I knew) but was hoping the rear disc brakes were somehow standard to the Dana 080. No luck with the parts catalog I got with the motor home. The Page for the rear brakes says "Service part numbers were not available at this printing". Looks like I've got a lot of research to do. Maybe I'll get lucky and will find a part number stamped on the caliper.
  • Okay. This is the part numbers from my invoices:
    Front Caliper: S55251X
    Front Pads: MD224
    Front Brake Hose: 10-638
    Rear Caliper: 60050150X
    Rear Pads: DP224
    Rear Brake Hose (right): W1338 (OEM) or 10-638
    Rear Brake Hose (left): W1621 (OEM) or 10-637
    These parts are made by many different manufacturers so #'s might be different but still fit. For instance, brake pads have a different suffix but the same 224. All these parts were purchased from Freightliner.
    This website might help as well: http://store.stepvanparts.com/BRAKE-JOHN-DEERE-STEPVAN.HTM
    Hope this helps everybody. Keep RV'n!!
  • That is awesome information. Haven't been on in a while so just saw your posts. Amazing! A post nearly a year old gets results.
    All hail the power of helpful RVers and rv.net! :)
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
