landyacht318
Apr 27, 2014Explorer
I've recently been considering the AGM full when it accepts less than 0.1 amps at 14.6v.
Though when new it refused anything more at 14.6v but had a rested OCV of 12.84v. It wasn't until I did a 50% discharge then a 25 amp recharge that it seemed to "wake up" and hold nearly 13.1 rested OCV. It also seemed to crank the engine noticeable quicker after the 50% discharge and 25 amp recharge initial cycle.
I just found that Northstar has rebranded a 25 amp Ctek charger that has a temperature probe and says it can be a power supply too. I know 14.4v would be inadequate for my flooded battery, but I'd like to replace my 25 amp Schumacher and do not think I require a 45+ amp Iota PD or Powermax converter.
http://www.northstarsitetel.com/1.0.1.0/254/NSBC_25.pdfhttp://www.northstarsitetel.com/1.0.1.0/254/NSBC_25.pdf
Not sure if the above product is a tweaked version of this product:
http://www.amazon.com/CTEK-56-674-Battery-Charger/dp/B0045F3SGY/ref=sr_1_2?ie=UTF8&qid=1398628385&sr=8-2&keywords=ctek+battery+25+amp
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
