AH64ID
May 01, 2014Explorer
I am using Lifeline AGM's for 300AH total.
They rest right around 13.00v ±0.5V, and are 50% SOC at 12.2V (the same as my flooded). That is a lot more energy to 50% SOC, they also seem to hold a higher voltage longer.
The AGM also accepts a voltage must faster than the G24 flooded I had, this is due to both wiring upgrade and battery design. Wiring only goes so far and the 50-90 is very similar for nearly 175% more amp hours.
Lifeline states that their batteries are fully charged when the amperage drops to 0.5A per 100AH.
I only have one or two cycles to 50% SOC and then a full charge on them. They just don't get low enough in several nights of camping, even with normal heater use and temps in the high 20's.
