MEXICOWANDERER
Sep 11, 2020Explorer
Being in Mexico, jumper cables are assembled Chinese copper plated toy steel clamps and 8 gauge copper-plated aluminum super thick vinyl insulation. There is an ad on Amazon for a seventy+ dollar PAIR (I need four) of Associated clamps that look good. $150.00 for four clamps seemed sorta pricey.
DLO insulation itself is great but specs call for it to be thick. Which shrugs off cuts, and nicks. And makes it a lot heavier. This is going to be a gift for a beefy 38-year-old mechanic and his tow truck. Connections will be mechanically crimped. Then the entire wire tip and the serrated copper pad are going to be dipped into molten lead. This stops battery acid corrosion and salt air corrosion forever. After that, the cable and the coated tip is slid up the handle under the wire spring and screwed into place. I have the 316 stainless 10/28 screws.
Like the Borg and the Gigawatt when I build something it is likely to endure many decades of commercial use and laugh it off.
But since 1980 many companies have gone under. If I wanted to buy "The Best" commercially made battery charger I would choose the Associated Twelve hundred dollar unit. But I build chargers that run circles around the Associated and will outlast them. But no 150 dollar clamps, please. :D
being
being
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
