MEXICOWANDERER's avatar
Sep 11, 2020
Jumper Cables A Jumble Of Compromises
I've had an unused 30 feet of 4 AWG DLO cable sitting around for a number of years. I have decided to make jumper cables. DLO cable is the thickest and toughest insulation of them all and the conductor is double thickness tin-plated rope stranded. The cable is too heavy for me but put to commercial use, with super quality ends (clamps) they should be a forever set of commercial jumper cables.
But I'm going to ask for advice from folks who have made up their own cables recently.
Since the wire stranding toll is to be squashed then soldered about the only stuff that is concerning is the fastener that holds the cable wire to the jaw clip. I will use 8awg silicone wire as a jaw to jaw shunt.
The pesky huge spring will have to be pried open and the cable slipped beneath by a friend younger and stronger than me.
Have you encountered super clips on the market?
  • Not sure what you're asking. 4ga DLO cable is stranded so you can either hook it mechanically to jumper cable ends available at auto supply stores, solder it, or have someone swedge the wire to cable eye pieces and bolt these to the clamps. I can believe the insulation on this cable is stiff, but I just don't understand the question. Could you please elaborate?
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
