Almot's avatar
Almot
Explorer III
Jan 05, 2018
Just curious - why Lithiums are so heavy?
100 AH, flooded, 66-69 lbs.
100 AH, Li, 29-31 lbs.
Brain-dead sellers jumping on a new bandwagon, "One-fifth the weight of a traditional battery", yahooo....
More usable capacity, yes, but not 2 or 3 times more. 70-75% of Li vs 50% of flooded, this is 1.4-1.5 times more capacity.
I'm curious, is there any drop-in Gr31 Lithium, 12V, with BMS, that weighs less than 25 lbs?
  • Almot wrote:
    Electric car battery works in different conditions, it has (I think) liquid cooling system that drop-in batts don't.
    I'm not sure it really goes down to 5%, what you see on display is not necessarily it, they might show you only % of a "usable charge", but I don't have electric car. Common recommendation for drop-in 12V Li, and 24-36-48 batts of scooters, ebikes etc is running it in 20%-90% SOC.
    Are the RV lithium ion batts ok with standard RV converters?
    It needs slightly higher bulk voltage, and Float voltage is zero - charging must stop when full. But let's not deviate.
    So... Anybody saw 20 lbs Gr31? ;)
    I think I remember reading that. When my car turtles (is completely dead) its not actually dead. The BMS controls that I believe. I have never turtled either car so don't actually know what happens.
    Probably not one you'd be willing to pay a grand for.
    Can't say I've heard too much complaining about their weight.
  • Charger voltage depends on the number of series cells and the cell chemistry
    The avg new 14+v converter is to high for a 3* 3.7v setup
    The liFePos are 3.2v per cell and use four cells in series
    4*3.2v
    An inexpensive 100 ampHr 12v LiFe made from 18 cells of Chevy volt battery
    Is $400
    A car box drop in is around $900
  • Almot's avatar
    Almot
    Explorer III
    Both our cars are Electric.
    I don’t know if I would do it all the time but we run our cars down to 5 to 10 percent once in awhile when we make a certain trip and don’t want to stop at a DC fast charge for twenty minutes. The cars don’t seem to care. Probably only a few times a year but that would probably be the same in the RV world.
    I haven’t looked into it much. Are the RV lithium ion batts ok with standard RV converters? What does a group 31 lithium ion cost nowadays.
  • Is that a lithium iron battery? I've read 80% capacity at a minimum, more depending on chemistry and management.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
