mchero's avatar
mchero
Just purchased a hot rod from CW, have a question.
This is for those of you that have installed a Hot Rod in their Atwood 6 gallon HWH.
I'm going to be spending 4 nights at the KOA in Old Orchard Maine. Will have full hookups and decided to install a Hot Rod in my Atwood 6gal HWH.
Big question I have is where do you place the thermostat? I understand it is supposed to be in direct contact with the tank so it can properly regulate the temp.
The existing thermostat and Hi-temp switch is under that black rubber pad just below the expansion valve
I do have access to the top of the tank by going thru the bathroom drawer. I plan to plug the hot rod into the outlet originally used for the washer/dryer that sat next to the HWH.
Note the picture below. It's the original hot water heater & I belive the original ignighter board! Just keep it clean and adjusted and no problems! I did replace the baffle in the upper left.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
