mchero's avatar
mchero
Just purchased a hot rod from CW, have a question.
This is for those of you that have installed a Hot Rod in their Atwood 6 gallon HWH.
I'm going to be spending 4 nights at the KOA in Old Orchard Maine. Will have full hookups and decided to install a Hot Rod in my Atwood 6gal HWH.
Big question I have is where do you place the thermostat? I understand it is supposed to be in direct contact with the tank so it can properly regulate the temp.
The existing thermostat and Hi-temp switch is under that black rubber pad just below the expansion valve
I do have access to the top of the tank by going thru the bathroom drawer. I plan to plug the hot rod into the outlet originally used for the washer/dryer that sat next to the HWH.
Note the picture below. It's the original hot water heater & I belive the original ignighter board! Just keep it clean and adjusted and no problems! I did replace the baffle in the upper left.
  • I've had my Hot Rod for over 12 years and it works great and it will produce hot water in 30 to 45 min or so and save all that gas.
    You should install the T-Stat in the middle of the tank for best results, I just leave mine plugged in and use the switch I have to turn it on. My T-Stat is set at 125 deg which is plenty.
    One additional note : I do not have it on if I'm on inverter, it does draw amps.
  • RoyB's avatar
    RoyB
    Explorer III
    mchero - If it is in the 400WATT range I would try and use it on my inverter for when camping off the power grid. Would sure beat using up my propane to keep hot water going... Once the heat is up to temperature the gas furnace doesnt kick on very much here... Probably same deal with an electric element.
    I need it for a PLAN B in my setup for sure.... My hot water may be my source of HYDRONIC HEAT for my trailer soon so will need HOT WATER all the time when camping off the power grid. I have got to get rid of my trailer propane heater and its high current 12VDC fan for sure...
    Of course if the HOT ROD is high current then my INVERTER will be too small to run that... I need to run down the specs on it. I have seen lower wattage elements available in the 400-500WATT range.
    I did see something hiding behind the propane igniter - didnt know if that was your HOT WATER drain plug or not. Hopefully the photo is making its location looking like its behind the igniter. My Suburban Model is definitely out of the way of anything on the bottom like I showed in my photo. I remove this plug to drain my hot water heater when winterizing.
    What you got sounds interesting...
    My entire water heater is of course covered with a heat pad so if the temperature sensor has to touch the metal case of the hot water heater than you will have to cut some of the padding out to attach the sensor. Sure don't want to drill a hole through the outer case hehe...
    Roy Ken
  • One reason I supersized the picture is so that users can see the drain valve, It's just to the left of the gas valve. I'll have to remove & insert the Hot Rod.
    I will NOT try & use the Hot Rod on my inverter. As stated above I'll ave full hookups. I'd never try & run off the inverter.
  • RoyB's avatar
    RoyB
    Explorer III
    I am assuming this is the HOT ROD kit you are referring too... How many WATTS is this device... Hopefully something you can run from an INVERTER when you are running off the power grid.
    This will have to inserted into the HOT WATER HEATER and from the photo you posted I don't see the bottom unused drain port my Surburban model has. It may be hidden by your propane pilot light assy and I cant see it.
    My water drain port shown on the very bottom here is a standard size port where you would screw in the HOT ROD element.
    Where are you going to insert the electric element into your hot water heater.
    Roy Ken
  • If it were me, I would return that hot rod. They do not heat the water that quickly, unlike the factory electric tanks. For the money you paid for that hot rod, you can buy a good amount of propane to heat your water. Also, you have an old heater...my experience is when you start messing with something old it starts to break.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
