jschultzuw's avatar
jschultzuw
KIB Micro Monitor
Need to replace KIB Micro Monitor. Mine is stamped 1997 and is oriented horizontally. The new boards I'm seeing are oriented vertically but have the exact same readouts: battery, gray, black and fresh as well as the pump switch. Are the pin harnesses the same for the old and new models? Or do I need to order one of those too?
Thanks,
Jason
1 Reply
  • I replaced a KIB monitor panel in a 1992 model trailer in about 2003, and I believe I just plugged in to existing connector and was a fairly easy change.
    I ordered the new panel directly from the factory.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
